waqasazfar
Oct 16, 2023Aspirant
RBR750 + RBS350 connection problem after FW upgrade
RBK653 — Orbi Tri-band Mesh WiFi 6 System (1) Orbi Router (RBR750) + (2) Orbi Satellites (RBS350) previously i updated my satellites manually with firmware V4.20.0.4 https://kb.netgear.com/000...
waqasazfar
Let me explain again.
i downgraded my router to FW V4.6.14.3 and it start working again normally and satellites are connected automatically. but Satellite versions are different.
i had plan to change FW version of Satellites manually different FW (4.6.14.3), but when i login to satellite directly from IP, only white blank page shows, same is happening for both satellites.
Currently i am on different Satellite FW and unable to update as satellite login pages are not showing anything.
Oct 16, 2023Guru - Experienced User
Try this to see if this works:
What you need to do is factory reset the RBS. Wire connect a PC to the 1st satellite📡. Already have the FW version files downloaded on to this PC. Use MS Edge or Firefox for this.
You'll need to turn OFF the RBR to ensure the RBS don't connect to the RBR. Wire connect 1 PC to the back of the RBS. Factory reset the RBS, wait about 5 minutes. The PC will get a IP address from the satellite📡or try setting a static IP on the PC for 192.168.1.49. The RBS will be 192.168.1.250. Use this IP address in a web browser to log in to the satellites web page. Log in as admin and password. Use the satellites 📡 web page FW update feature to select the FW update file that was unpacked from the .zip file. Then factory reset and then re-sync the satellites 📡 to the RBR.
Or try TFTP to get the RBS back to the lower FW version:
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
Need to press the reset button for 30 seconds then release, then it send to PUT the command and upload the FW.
Make sure you enable tftp: https://www.thewindowsclub.com/enable-tftp-windows-10
Video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done:
https://www.youtube.com/watch?v=hXhMgQS5k1o
https://www.youtube.com/watch?v=R9DLrLQrpaw
Mac TFTP: https://www.petenetlive.com/KB/Article/0001247
Try nmrpflash:
https://github.com/jclehner/nmrpflash
- waqasazfarOct 16, 2023AspirantOk i will try it, i dont have laptop with ethernet port righ now.
But as you mentioned already, FW version in both RBR and RBS need to be same, in that i wont be able to update to RBR750 V7 anyway because same version is not available for RBS350
Right?- FURRYe38Oct 16, 2023Guru - Experienced User
They have USB to ethernet adapters.
Correct.
in that all this effort seems useless, because even with slight difference in FW, my RBS350 and RBR750 are working together, only problem is RBS350 is not connecting when i upgrade RBR750 to FW V7
Thankyou for your support FURRYe38
i think i should wait until new version for RBS350 is also available.
