zrdcorp
Dec 18, 2021Tutor
RBR750 / RBS750 AP MODE NOT ACHIEVING STABLE WIRELESS BACKHAUL
I searched for a solution for this to no avail. I have tried all firmwares 4.6.3.7 and above. If i switch to AP mode they never get a stable wireless BACKHAUL. I have tried varying distan...
Dec 19, 2021Guru - Experienced User
Make sure when you downgrade, that the system doesn't auto update. The system will update if it's not blocked.
Some you'll need to contact NG support about.
Rudolphy
Dec 20, 2021Apprentice
Just for info: My RBR50 also runs in AP-mode with 3 RBSs at latest firmware. No issues so far. Furry is not the only one :-)
But my RBSs do a resync a few times a day, but internet connection is stable while this process. This behavior only exists with firmware 4.xxx
