zrdcorp
Dec 19, 2021Tutor
RBR750 / RBS750 AP MODE NOT ACHIEVING STABLE WIRELESS BACKHAUL
I searched for a solution for this to no avail. I have tried all firmwares 4.6.3.7 and above. If i switch to AP mode they never get a stable wireless BACKHAUL. I have tried varying distan...
Dec 20, 2021Guru - Experienced User
Just curious, do ALL your RBS resync all at the same time or randomly?
I only have 1 RBS and haven't seen this with mine. Would be interesting to know if you turn OFF all but 1 RBS, still happens?
Your system been fully factory reset and setup from scratch?
Rudolphy wrote:
Just for info: My RBR50 also runs in AP-mode with 3 RBSs at latest firmware. No issues so far. Furry is not the only one :-)
But my RBSs do a resync a few times a day, but internet connection is stable while this process. This behavior only exists with firmware 4.xxx
claudiut
Dec 21, 2021Apprentice
FURRYe38 As you probably read here most of us having satellite disconnect issues it's always random, one of the satellites at a time. Also, what's the point in turning OFF all but 1 satellite?? I need all the satellites for coverage otherwise the system is useless!
If you're trying to troubleshoot the issue, please feel free to buy an additional RBS and help NG troubleshoot the issue. It seems you like them so much anyway.
Another point here: stop asking people to reset their system and reconfigure everything. When you pay this much on a system it should just at a push of a button. What you and NG are doing in equivalent of a car manufacturer asking me to reset a car's system in order to try to make it work properly. Instead you should ask your friends/colleagues at NG to work harder and come up with a firmware that actually works!
FURRYe38 wrote:Just curious, do ALL your RBS resync all at the same time or randomly?
Rudolphy wrote:Just for info: My RBR50 also runs in AP-mode with 3 RBSs at latest firmware. No issues so far. Furry is not the only one :-)
