g33kguy's avatar
g33kguy
RBR750 1 Lan port internet d/l speed fast, 2nd port slow (under 100mbps)
Hello. I have my Orbi router ethernet connected to Verizon router with 1 gig service. I have wired connection from Xbox into Lan port 1 of the Orbi and a FireTV cube wired connection into Lan port...
  • microchip8's avatar
    Jul 18, 2023
    Maybe the FireTV gizmo only has a 100 Mbps chip inside? Ever thought of that? Check its specifications.
    EDIT.
    Yup, it only has 100 Mbps ethernet chip.
    "Additional ports: HDMI port so you can connect and control other entertainment devices with just your voice, USB-A 2.0 for added storage, Ethernet port 10/100 Mbps for wired access"
