Sparky61
Jun 09, 2023Aspirant
RBR750 addition
Hi i dyslexic so can someone explain in plain english I have a RBR750 with 2 satellites but I need to add another one. Is it possible, do I have to use a particular one. I used to have a RBK23 can I add one of those satellites to the 750 or must it be the same model and if so how do I do it?. Thank you kindly
Only the following RBS can be added to a 7 series system:
https://kb.netgear.com/000065169/Which-Orbi-routers-and-satellites-are-compatible
Also EX and EAX series extenders can be used in a pinch.
