bpd
Jan 24, 2022Aspirant
RBR750 admin page won't load -- responds to ping but not HTTP GET
I have a brand new RBR750 (orbi AX4200) and can't load the admin page (192.168.1.1/orbilogin.com) to setup the router even over a wired connection after a factory reset. The router responds to pings ...
Jan 25, 2022Guru - Experienced User
bpd
Jan 25, 2022Aspirant
Is there a way to determine the firmware version without access to the admin page or orbi app? Maybe through a console port or something? Otherwise I don't think it's possible to determine the firmware version.
The issue is not related to my ISP modem, since it was the same behavior before connecting the orbi to the ISP modem. But for reference it's an Arris BGW210.
- FURRYe38Jan 26, 2022Guru - Experienced User
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopYou may need to disconnet the RBR fron the ISP Modem and factory reset the RBR and set it up from scratch with out it being connected to the ISP Modem first. You should be able to access 192.168.1.1 on the RBR using a web browser and wired PC connected.
- bpdJan 26, 2022Aspirant
Your last sentence "You should be able to access 192.168.1.1 on the RBR using a web browser and wired PC connected." captures the problem -- I am unable to access 192.168.1.1 on the RBR even after a factory reset and wired PC connection.
- FURRYe38Jan 27, 2022Guru - Experienced User
And you reset the RBR by pressing the reset button for 15 seconds then release and with the RBR not connected to the ISP modem?
