RabieL
Dec 07, 2023Aspirant
RBR750 and 2 RBS750, nightmares, almost non-usable
I purchased 2 RBK752 kits, but currently working with 1 Router and 2 Satellites. From day 1 when I first configured it I started to see issues as my iphone had hard time connecting to it - it keeps...
RabieL
No, I think it's customized one for the ISP, here I found some English information about it.
https://mypc2020.co.il/Catalog.asp?Page=NewShowProd.asp&PRodID=1981676
Dec 07, 2023Guru - Experienced User
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...
Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Turn OFF the RBS and just test with the RBR alone for now.
So the RBS are ethernet connected to the RBR? If so, how are they connected, is there a LAN switch or patch panel in between the RBR and RBS? Brand and model of switch if one is in use please.
- RabieLDec 07, 2023Aspirant
Hi,
I already configured #2, but it doesn't help.
before Orbi I also had a mesh system connected to this Modem-Router and I had no issues.
I have disabled its WIFI, and configured DMZ.
- FURRYe38Dec 07, 2023Guru - Experienced User
Hi,
I set 2.4G channel to 11 (I see it using 11P+7S)
I set 5G channel to 48 (I see it using 36+40+44+48P)
and I still facing the issue.
regarding power off the RBS and use only RBR I can check it only tomorrow - as I need to change a floor.
