RabieL
Dec 07, 2023Aspirant
RBR750 and 2 RBS750, nightmares, almost non-usable
I purchased 2 RBK752 kits, but currently working with 1 Router and 2 Satellites. From day 1 when I first configured it I started to see issues as my iphone had hard time connecting to it - it keeps...
Dec 07, 2023Guru - Experienced User
Let try with the RBR alone for now.
Then can you disconnect one RBS from the ethernet connection and let it wirelessly sync to the RBR?
Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
RabieL
Dec 08, 2023Aspirant
Tried with RBR only, same issue, took my iphone half an hour to get a stable connection.
