booge's avatar
booge
Follower
Feb 11, 2024
RBR750 and 3 RBS750 keep on rebooting randomly
Latest Firmware, the system keeps on rebooting, I have read the forums and one of the suggestions spoke about activating email logging, I have no idea why they would solve the problem but it did not. this is running my Home-Office and I have invested a lot of money in Orbi system. I see this is an issue that happens to others
1 Reply
  • FURRYe38's avatar
    How was the FW updated? Manually or Orbi app or Automatic?
    Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
    How are the RBS connected? Wireless or wirelessly?
    What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR📡 and RBS🛰️ to begin with depending upon building materials when wired or wirelessly connected.
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰
    Does this happen with the RBS turned OFF?
    Does this happen with both wireless and wired devices?
    What channel configurations are currently set on the router?
    Armor, Smart Parental Controls or Circle, Traffic Meter.
    Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
    Turn off and unplug modem.
    Turn on computers and rest of network.
