PBMelbourne
Sep 29, 2022Aspirant
RBR750 and Moto E32
I’ve just bought a new Moto E32 for my daughter - it can see neighbour’s wifi connections and I can hotspot it to my wifi - but it cannot/will not pick up my wifi from my Orbi. I’ve entered the net...
- Sep 30, 2022
Does it show up if you disable AX?
CrimpOn
Sep 29, 2022Guru - Experienced User
This is a new one (for me). WiFi devices tend to display the WiFi names (SSIDs) of all nearby networks, along with some symbol indicating relative signal strength (bars?). The Orbi WiFi does not appear at all?
PBMelbourne
Nope, my Orbi wifi SSID doesn't make an appearance at all.
About 30 other devices including friends phones and tablets of all makes and models have all hooked up with no problems, but this phone shows everything but the Orbi SSID.
I've rebooted everything multiple times and I'll update the router and satellite firmware when I get home, but other than that I've got no idea what to do next!!!
- plemansSep 30, 2022Guru - Experienced User
- PBMelbourneSep 30, 2022AspirantI wish I understood what that meant!
Many thank plemans - disabled the AX and it popped up immediately....
- plemansSep 30, 2022Guru - Experienced UserNow that you have it online, see if there's any updates for the phone.
