Cookinjh53
Oct 13, 2022Follower
RBR750 and RBS 750 Satellite
RBR 750 Router and RBS 750 Satellite The RBR 750 Router does not have USB ports so how do I connect a printer or an external hard drive with a USB connection or other devices which have USB conne...
Oct 13, 2022Guru - Experienced User
If your looking to connect a USB printer to the system and network it for everyone, I recommend you try a USB Printer to Print Server device that you would connect the printer to then the Printer Server device would connect via ethernet to the system.
