maccabout2
Jan 08, 2022Guide
RBR750 and RBS750 - switching bands on devices for faster performance
Just finished setting up my AX4200 system throughout the house. Would like to know how I can switch bands between 2.4 and 5 Ghz on each connected device? Or at least have the option of choosing on ea...
- Jan 08, 2022
Neither of these setting options have been available and are unlikely to release with future updates.
McLong
Jan 08, 2022Luminary
- CrimpOnJan 08, 2022Guru - Experienced User
This question comes up frequently. As indicated above, the WiFi system has no mechanism to force a device to a specific WiFi band.
All those Internet of Things (IoT) devices have only a 2.4G radio, so they can connect only to the 2.4G band.
For many other devices, a 2.4G connection is adequate. Streaming 4K video requires at most a 25mb/s connection.
There are devices that definitely have the capability to restrict WiFi to certain bands. Windows laptops, for example, usually have an option in "Properties" to restrict which WiFi bands can be used. My Lenovo laptop, for example, allows the WiFi to be set to 2.4G only, 5G only, and even to certain subsets of those bands.
- maccabout2Jan 08, 2022Guide
Thanks. My SurfaceBook 2 only allows 2.4 Ghz connection in the properties.
So far my new ORBI is making a huge difference. Can't wait to test on my next Zoom/Teams call.
