Barre_A
Aug 10, 2021Aspirant
RBR750 and RBS750, keeps disconnecting. Some devices is still connected, need reboot.
I have Orbi mesh RBR750 with RBS750, distance between these is 8 meter. My devices are disconnected from my router. I live in an apartment of 80 sqm. Sometimes I have 5 devices connected and so...
Aug 10, 2021Guru - Experienced User
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Armor, Set 20/40Mhz Coexistence to 40Mhz only. Set CTS to 2347. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings
You can find other speed diagnosis steps in the community faq: https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-t-my/m-p/1982974/highlight/true#M7849
Barre_A
Aug 12, 2021Aspirant
Firmwire : V4.6.3.7_2.0.49
i don't know MFR model#
i have now tried to set different chanels for 2,4Ghz and same for 5Ghz.
I have a couple of neighbors, but if Orbi can't handle some neighbours then that router is not for me. I have tried other routers and they can handle that.
I did turn of those things.
Seems that these steps is allway asked to be done no matter the issue, but this did not help me. any other things i can do or can i return my product ?
- FURRYe38Aug 12, 2021Guru - Experienced User
Ask the place of purchase about return policies.
