Mstrbig
Dec 12, 2020Master
RBR750 and RBS750 new firmware V3.2.16.22_1.4.9
A new firmware V3.2.16.22_1.4.9 push for the RBR750 router and RBS750 satellite came out today. Since I always install the latest firmware when it comes out, I updated my RBK753S system. The update ...
ctships
Dec 18, 2020Aspirant
I updated the firmware and lost 1 of 2 sattelites. I moved it next to the router but it wont connect. Looking for any help...
Dec 18, 2020Guru - Experienced User
Besure RBS updated FW with same version as RBR.
Factory reset the RBR and RBS...
- Bma398Dec 28, 2020Aspirant
upgraded to V3.2.16.22_1.4.9 via the ORBI App, within 24 hours Orbi was having trouble talking to FIOS router, even with static IP assigned the orbi WAN port was showing no connection to router.
had to factory reset the orbi to get it to work, once i went thur new setup, orbi seems to be working
i did end up changing the port on FIOS router and changing out ethernet cable.
just posting in case other had this issue with firmware upgrade.
- MstrbigDec 28, 2020Master
Bma398 wrote:upgraded to V3.2.16.22_1.4.9 via the ORBI App, within 24 hours Orbi was having trouble talking to FIOS router, even with static IP assigned the orbi WAN port was showing no connection to router.
It's always a good idea, after a firmware update, to reboot the Orbi and an internet modem or modem/router one may have.
- FURRYe38Dec 28, 2020Guru - Experienced User
I would power OFF both RBR and FIOS unit for 30 seconds, then back ON with the FIOS unit first, then RBR.
