Mstrbig
Dec 11, 2020Master
RBR750 and RBS750 new firmware V3.2.16.22_1.4.9
A new firmware V3.2.16.22_1.4.9 push for the RBR750 router and RBS750 satellite came out today. Since I always install the latest firmware when it comes out, I updated my RBK753S system. The update ...
TheTraveller
Apr 04, 2021Aspirant
Sorry to say I upgraded to this version and it is so seriously flawed.
I originallyy had an Orbi RBR50 with satellites where the entire system went haywire, to the point you put more than one satellite on and the system went into a total reboot loop, so bit the bullet and upgraded.
Everything was fine until this release of firmware, now:
- You can log straight into the config from a browser without a username or password
- Despite setting the Guest Network to OFF, the system periodically advertises the guest network, you can connect to it, but the Orbi app and the browser both show it is turned off
- With Access Control set to ON and Block all new devices, when you allow a device to connect (after it has been blocked), the device still will not connect. You need to block it a second time and then re-allow it.
I would recommend, NOT upgrading until this version is thoroughly tested and the bugs removed.
Having logged a support ticket, the only response was to factory default the system and start again, sorry but this is a brand new build out of the box working fine until the latest firmware.
Be cautious
- MstrbigApr 04, 2021Master
Why are you running V3.2.16.22_1.4.9 when V3.2.17.12_1.4.14 is available and completely stable. We have many systems running it with no complaints.
https://www.downloads.netgear.com/files/GDC/RBK752/RBR750-V3.2.17.12_1.4.14.ziphttps://www.downloads.netgear.com/files/GDC/RBK752/RBS750-V3.2.17.12_1.4.14.zip
- TheTravellerApr 04, 2021Aspirant
Hi,
Thanks for this. The reason I wasnt runing V3.2.17.12_1.4.14 is that despite checking numerous times neither the Orbi App or the router "check for updates" actually identified any newer updates.
Also when I logged a support call with the wonderful Netgear support they never even mentioned a newer version and simply suggested reboot or factory default and rebuild.
Hey Ho. Got this version on now. Crossed fingers.
Thanks
- FURRYe38Apr 04, 2021Guru - Experienced User
v12 was never put up on the update server by NG. Only inteded for manual download. So it won't appear on Orbi app or on the RBRs web page as something availalbe for update.
Good Luck.
