Mstrbig
Dec 11, 2020Master
RBR750 and RBS750 new firmware V3.2.16.22_1.4.9
A new firmware V3.2.16.22_1.4.9 push for the RBR750 router and RBS750 satellite came out today. Since I always install the latest firmware when it comes out, I updated my RBK753S system. The update ...
TheTraveller
Apr 04, 2021Aspirant
Sorry to say I upgraded to this version and it is so seriously flawed.
I originallyy had an Orbi RBR50 with satellites where the entire system went haywire, to the point you put more than one satellite on and the system went into a total reboot loop, so bit the bullet and upgraded.
Everything was fine until this release of firmware, now:
- You can log straight into the config from a browser without a username or password
- Despite setting the Guest Network to OFF, the system periodically advertises the guest network, you can connect to it, but the Orbi app and the browser both show it is turned off
- With Access Control set to ON and Block all new devices, when you allow a device to connect (after it has been blocked), the device still will not connect. You need to block it a second time and then re-allow it.
I would recommend, NOT upgrading until this version is thoroughly tested and the bugs removed.
Having logged a support ticket, the only response was to factory default the system and start again, sorry but this is a brand new build out of the box working fine until the latest firmware.
Be cautious
Mstrbig
Apr 04, 2021Master
Why are you running V3.2.16.22_1.4.9 when V3.2.17.12_1.4.14 is available and completely stable. We have many systems running it with no complaints.
https://www.downloads.netgear.com/files/GDC/RBK752/RBR750-V3.2.17.12_1.4.14.zip
https://www.downloads.netgear.com/files/GDC/RBK752/RBS750-V3.2.17.12_1.4.14.zip
