Mstrbig
Dec 11, 2020Master
RBR750 and RBS750 new firmware V3.2.16.22_1.4.9
A new firmware V3.2.16.22_1.4.9 push for the RBR750 router and RBS750 satellite came out today. Since I always install the latest firmware when it comes out, I updated my RBK753S system. The update ...
Mstrbig
Apr 04, 2021Master
Why are you running V3.2.16.22_1.4.9 when V3.2.17.12_1.4.14 is available and completely stable. We have many systems running it with no complaints.
https://www.downloads.netgear.com/files/GDC/RBK752/RBR750-V3.2.17.12_1.4.14.zip
https://www.downloads.netgear.com/files/GDC/RBK752/RBS750-V3.2.17.12_1.4.14.zip
TheTraveller
Apr 04, 2021Aspirant
Hi,
Thanks for this. The reason I wasnt runing V3.2.17.12_1.4.14 is that despite checking numerous times neither the Orbi App or the router "check for updates" actually identified any newer updates.
Also when I logged a support call with the wonderful Netgear support they never even mentioned a newer version and simply suggested reboot or factory default and rebuild.
Hey Ho. Got this version on now. Crossed fingers.
Thanks
