Toughguy5
Jun 17, 2022Guide
RBR750 and two sats.
Firmware Version: V4.6.8.5_2.1.9 RBR750 and 2 sats my wife called to say internet went down at 12:45pm today. i called comcast and they confirmed inter was up and no issues were det...
Jun 17, 2022Guru - Experienced User
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
- Toughguy5Jun 17, 2022Guide
Product Type:XB7
YES.
Turn on computers and rest of network.completed many times.
3000sq.
From the router to the satellites is about 35 feet to each ORBI also in a triangle shape form . house is wood framed.
this is correct and done.
not to many WIFI people in the neighborhood.
thank you.
- FURRYe38Jun 17, 2022Guru - Experienced User
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop- Toughguy5Jun 17, 2022Guide
my bad, Comcast modem is already in bridge mode. i just tried to factory reset the Orbi router and now the App dont work anymore and my devices are still getting on and falling off.
