Toughguy5
Jun 17, 2022Guide
RBR750 and two sats.
Firmware Version: V4.6.8.5_2.1.9 RBR750 and 2 sats my wife called to say internet went down at 12:45pm today. i called comcast and they confirmed inter was up and no issues were det...
Toughguy5
Jun 17, 2022Guide
Product Type:XB7
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
YES.
Turn off and unplug modem.
Turn on computers and rest of network.
completed many times.
3000sq.
What is the distance between the router and
satellite(s)? 30 feet or more is recommended in between RBR and RBS
to begin with depending upon building materials when wirelessly connected.
From the router to the satellites is about 35 feet to each ORBI also in a triangle shape form . house is wood framed.
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
this is correct and done.
not to many WIFI people in the neighborhood.
thank you.
Jun 17, 2022Guru - Experienced User
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
- Toughguy5Jun 17, 2022Guide
my bad, Comcast modem is already in bridge mode. i just tried to factory reset the Orbi router and now the App dont work anymore and my devices are still getting on and falling off.
update:
as of now no more then 31 devices will connect, they will drop off and keep trying. I cannot use this ORBI since it wont allow all my devices to connect, I just don't know why. back to Costco you will go if no fix is available ...
has anybody tried these...
NETGEAR - Orbi AX5400 Wi-Fi 6 Mesh System, One Year Advanced Internet Security Included
Item 1616261
Model RBK763S
can anybody recommend something different and better ?
- Toughguy5Jun 18, 2022Guide
i have returned this Model RBK763S back to Costco. way to may problems.
thanks.
