TelcoPro
Sep 30, 2023Follower
Rbr750 ap mode chaos wired backhaul
Some time ago I bought by impuls Netgear equipment for at home. I thought why not use some WiFi 6 mesh system and keep the intelligence out of it to integrate in my more advanced Lan (fw, DHCP, dns, n...
Oct 02, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
How many RBS are deployed?
How are the RBS connected to the RBR via ethernet? Directly to the back of the RBR or is there a LAN switch in between them?
Does this happen with the RBS turned OFF?
Does this happen with both wireless and wired devices?
What channel configurations are currently set on the router?
How is the RBR configured for AP mode? Dynamic IP or Static IP configuration?
