zombywoof
Oct 04, 2024Aspirant
RBR750 ap mode wired backhaul, wan port=internet/no synced sats, lan port=no internet/synced sats
I'm stuck. I have a RBR750 and 2 RBS750 satellites. All are upgraded to firmware V7.2.6.31(_5.0.24). I did a reset on all devices and started out new. First I've set the RBR to AP mode and choose d...
- Oct 04, 2024
Fixed it.😀
I went back to firmware V4.6.14.3_2.3.12, didnt even reset to factory, kept all settings and all problems disappeared.
Now i can connect to the RBR LAN port.
I'm able to ping the RBR perfectly
The RBR sees and syncs the satellites over wired backhaul over multiple switches.
The wireless clients get 500-600 Mbps internet everywhere in the house
Conclusion: the firmwares above V4.6.14.3_2.3.12 destroy AP mode.
Oct 04, 2024Guru - Experienced User
Last time I had my 750 series online with RBS had tested AP mode with RBS ethernet connected. All worked. That was on v.21. I'll check my 750 series again while in AP Mode and see whats happening. I see I updated my system back on 4/25 to v.31. Will test AP Mode first and see what I find out.
zombywoof
If you test with any 7.2 version, try:
laptop - LAN PORT RBR750 and then ping RBR -t (this will work)
laptop - switch - LAN PORT RBR750 and then ping RBR -t (this willl give lots of timeouts)
- FURRYe38Oct 04, 2024Guru - Experienced User
So go my RBK752 system up and running.
First off was RBR in router mode to make sure RBS wireless and ethernet connected to the RBR.
HP 1400 series non managed switch used in between.
Then configured AP mode and use a RAX80 for host router.
Left RBS ethernet connected to switch and switch connected to RBR after applying AP mode configuration:
Gave several minutes for everything to settle in. 192.168.1.75 IP static IP address used on RBR for AP mode:
RBR AP mode connected devices page:
RBS web page:RBS connected devices page:
Ping results with ethernet connected PC behind the RBR:
Ping results with same ethernet connected PC behind the HP LAN switch connected behind the RBR:
- zombywoofOct 05, 2024Aspirant
Can you try a ping -t (keep pinging). And wait a while.
In your picture:
Also remarkable, with 7.2 it does not show it's IP. With 4.2 it does show it's IP.
- FURRYe38Oct 05, 2024Guru - Experienced User
Ya thats a bug we found back on v.21. Reported it. Still on going. Doesn't effect much. Just a UI display issue.
