milan7
Apr 06, 2025Aspirant
RBR750 assigning DHCP ips every 30 seconds according to logs. Router reboots randomly 2x a month
1 RBR750 1 RBS750 Firmware : V7.2.7.15_5.1.16 Last Reboot : April 1st, around 5:20pm Logs are in this shared folder Netgear 2 Issues : Frequent DHCP assignment and Random Reboots 2-3 times a...
Apr 06, 2025Guru - Experienced User
First time seeing this?
What brand and model# devices do you have connected?
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
How many RBS are deployed?
Does this happen with the RBS turned OFF?
Does this happen with both wireless and wired devices?
What channel configurations are currently set on the router?
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Orbi-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220016/jump-to/first-unread-message
Armor, Smart Parental Controls or Circle, IPv6, All Logging, Traffic Meter.
milan7 wrote:
1 RBR750
1 RBS750
2 Issues : Frequent DHCP assignment and Random Reboots 2-3 times a month.
If i reserve a specific IP, frequency slows down
