milan7
Apr 06, 2025Aspirant
RBR750 assigning DHCP ips every 30 seconds according to logs. Router reboots randomly 2x a month
1 RBR750 1 RBS750 Firmware : V7.2.7.15_5.1.16 Last Reboot : April 1st, around 5:20pm Logs are in this shared folder Netgear 2 Issues : Frequent DHCP assignment and Random Reboots 2-3 times a...
CrimpOn
Apr 06, 2025Guru - Experienced User
What are the two devices that appear to be making DHCP requests so often?
DHCP servers do not spontaneously decide, "oh fun. Let's issue an IP to this device again (and again)." Some time ago, I documented a a situation where my Windows laptop would not have internet when it had gone to sleep when I closed the lid and then reopened it hours later The only way to get internet was to perform a restart. (that situation was cured with a Windows software update.)
I set up Wireshark to capture the Ethernet port and discovered that the laptop was sending out DHCP requests. The Orbi router was answering them correctly. But the laptop just send out another DHCP request.
milan7
I agree, DHCP servers should not, which is why this is strange.
The 4 devices that appeared most in the logs before i did address reservation, 3 were macbook pro's and 1 was apple watch. The strange thing is without making any changes to the laptops, the activity stopped after reservations, if the laptop was an issue we would still see a dhcp request.
What is the lease period of Orbi DHCP lease?
- milan7Apr 06, 2025Aspirant
First time seeing this? - have seen this for a while, since i started looking at logs as part of the reboot problem
What brand and model# devices do you have connected? - Apple macbook pro, 2019, 2021, 2024
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? - Motorola B12 (i had a SB6141 before which i thought caused the reboot problem so replaced with B12)
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended. - Yes, but i doubt this is causing DHCP issues between Orbi and end devices
How many RBS are deployed? - 1
What is the size of your home? Sq Ft? - 3000Does this happen with the RBS turned OFF? - Have not tried it
Does this happen with both wireless and wired devices? - Dont have any wired devices
What channel configurations are currently set on the router? - 2.4 Ghz (Auto), 5 Ghz (48)Be sure to disable any MAC Address randomizers on phones and pads while at home: Done
- FURRYe38Apr 06, 2025Guru - Experienced User
Try with the RBS disabled.
Ya, Apple seems to do with this Orbi systems.
Happened on older FW versions I bet.
Yes, it happened with previous version as well. Was really hoping that the latest firmware that was released recently would have a fix but same behavior.
Should i consider rebooting every week so at least i know the time (dont want a reboot happening during an important meeting since i work remotely full time). Not sure if there is a memory leak somewhere.
- CrimpOnApr 06, 2025Guru - Experienced User
Orbi routers I have observed use a one day lease (86,400 seconds). Devices which remain connected to the network should request a lease renewal two times per day. (about 43,200 seconds apart). Devices which disconnect from the network typically request an IP every time they reconnect.
