Blem
Dec 08, 2020Aspirant
RBR750 AX4200 losing connection to Netflix
I just got a new RBR750 AX4200 Router and 3 satellites. I have great speed throughout the house, but had Netflix lose connection twice last night with no clocking or warning. This didn’t happen before...
- Dec 08, 2020I called my ISP and they confirmed that I should go bridge mode. I did and I played 3 Netflix shows on 3 TVS at the same time for a couple hours with no problems. I hope that stays that way. Thanks for all the help.
Dec 08, 2020Guru - Experienced User
You modem already has a built in router, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
I would try option #3 on the Orbi system as it's the easiest to configure.
Blem
- FURRYe38Dec 08, 2020Guru - Experienced User
Enjoy. :smileywink:
