MNMarty
Mar 01, 2021Aspirant
RBR750 Can't connect guest network from satellite
I have the RBR750. Router in lower level with one satellite in main level. All good signal strength. Updated to newest firmware V3.2.16.22 Both main router and satellite have been rebooted. Satelli...
MNMarty
Mar 02, 2021Aspirant
Well that opened Pandora's box!
I tried rebooting router and satellite and the process would never complete using the phone app. I eventually reset both router and satellite. Tried that a few times. Finally added the second satellite even though I didn't need it for coverage. Finally got everything back up and running. I never unplugged and plugged in my router so many times.
Fixed the guest network issue but now have to rebuild the entire network.
Can someone tell me, do I have to have both satellites up and running to setup the system? Seems crazy to me.
The router is connected to a netgear switch. I disconnected that during setup as well.
Mar 02, 2021Guru - Experienced User
Do not use the Orbi app to reset or do FW updates with.
What is the Mfr and model# of the ethernet switch in the configuration?
