mattpoll
Jun 23, 2020Aspirant
RBR750, change a device from 2.4 to 5.8 network?
Hi there, I have two computers on my network, one on the 2.4 and one on the 5.8. I'd like them both on the same network (I'm assuming 5.8) for fast file transfers (I transfer 30-100 GBs on occasion, ...
Jun 23, 2020Guru - Experienced User
Be sure the wifi adapters support 5Ghz.
Most wifi devices pick and choose which frequency to connect too for dual band devices.
Also try turning down the power output of the RBRs wifi radios from 100% to 50% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
Be sure that CTS and RTS values are changed to 2347 under Advanced Tab/Advanced Settings/Wireless Settings
