01Strat9999
Jun 10, 2024Follower
RBR750 Changed network from spectrum to orbi. Windows 10 desktop won't recognize orbi network. No
All wifi devices are working fine Only desktop is disconnected.
Jun 10, 2024Guru - Experienced User
1. You have an RBR750.
2. What modem/gateway is it connected to? The Orbi isn't a modem. It needs to be connected to a gateway
3. What does the desktop say for its connection?
4. Did you try a different ethernet cable? Or is it connecting over wireless? You don't say
5. What wireless card is in the desktop if its wireless? And what driver is installed?
