KirbyH
Jan 15, 2024Follower
RBR750 Compatibility with 10B signal
Can someone tell me if the RBR750 tri-band WiFi 6 System will still work with a 10GB input signal? Doesn't have to be better than it is. Works fine now with a 1GB signal.
Jan 15, 2024Guru - Experienced User
Yes, it should though connection rate on the RBRs wan port will be 1Gb max.
https://kb.netgear.com/000064991/What-options-do-I-have-when-setting-up-a-multi-gig-connection
