jason1000000000
Nov 25, 2021Follower
RBR750 compatible extenders
Hi, I'm after some help advice, I have the RBR750 system with 3 satellite at home, old house with thick walls! one of the satellites will show magenta solid, daily, then I have to reboot? and all ...
Nov 25, 2021Guru - Experienced User
"old house with thick walls"
What are these walls made of? If its plaster lathe/adobe/brick/concrete, adding more satellites might not help at all.
With the orbi's using a wireless backhaul, if something is blocking the signal, its doesn't necessarily help to add more satellites. Sometimes you have to investigate switching to using the wired backhaul. You could do that with anything like a MoCa adapter, powerline adapter, or even just running ethernet wire.
