Senex_Unus
Dec 10, 2024Follower
RBR750 connection issues
Hi all, This may be a really simple answer to a frustrating question. I have Vodafone broadband (wifi turned off), with an Orbi 6 attached (RBR 750) (in AP mode). Of late, I have a number of devic...
Dec 10, 2024Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Is the RBR connected to the ISP router using the RBRs yellow WAN port while in AP mode?
Does this happen with the RBS turned OFF?
Does this happen with both wireless and wired devices?
What channel configurations are currently set on the router?
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Orbi-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220016/jump-to/first-unread-message
Has a power off for 1 minute then back ON with the ISP modem and router and satellites been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
