NetCrashNG
Apr 27, 2022Tutor
RBR750 CONNECTION_REFUSED loading admin interface
I just updated to the latest frimware RBR750-V4.6.8.2 and after everything came back... 192.168.1.1 actively refuses to connect (ERR_CONNECTION_REFUSED).
- Apr 27, 2022
I did a reset on the router (pin for 7seconds etc) and re-configured everything, and I'm back to normal.
After the reset, the router web interface answered immediately.
Apr 27, 2022Guru - Experienced User
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
- NetCrashNGApr 27, 2022Tutor
Both Satellite and Router were off for two minutes, yes.
- FURRYe38Apr 27, 2022Guru - Experienced User
Be sure to clear out all browser caches...
What browser are you using? Same thing happens with a different browser?
Are you wired or wireless connected to the RBR?
Happens on other PCs as well?
All browsers... wired or wireless. A device (presumably the router, since DHCP assigned it as the gateway) is there at 192.168.1.1, but won't respond to HTTP GET. I might try factory reset next.
