NetCrashNG
Apr 27, 2022Tutor
RBR750 CONNECTION_REFUSED loading admin interface
I just updated to the latest frimware RBR750-V4.6.8.2 and after everything came back... 192.168.1.1 actively refuses to connect (ERR_CONNECTION_REFUSED).
- Apr 27, 2022
I did a reset on the router (pin for 7seconds etc) and re-configured everything, and I'm back to normal.
After the reset, the router web interface answered immediately.
Apr 27, 2022Guru - Experienced User
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
NetCrashNG
Apr 27, 2022Tutor
Both Satellite and Router were off for two minutes, yes.
- FURRYe38Apr 27, 2022Guru - Experienced User
Be sure to clear out all browser caches...
What browser are you using? Same thing happens with a different browser?
Are you wired or wireless connected to the RBR?
Happens on other PCs as well?
- NetCrashNGApr 27, 2022Tutor
All browsers... wired or wireless. A device (presumably the router, since DHCP assigned it as the gateway) is there at 192.168.1.1, but won't respond to HTTP GET. I might try factory reset next.
- salazrApr 27, 2022AspirantI’m having the same problem. Also unplugged the router etc.
Any updates?
