NetCrashNG
Apr 27, 2022Tutor
RBR750 CONNECTION_REFUSED loading admin interface
I just updated to the latest frimware RBR750-V4.6.8.2 and after everything came back... 192.168.1.1 actively refuses to connect (ERR_CONNECTION_REFUSED).
- Apr 27, 2022
I did a reset on the router (pin for 7seconds etc) and re-configured everything, and I'm back to normal.
After the reset, the router web interface answered immediately.
salazr
Apr 27, 2022Aspirant
I’m having the same problem. Also unplugged the router etc.
Any updates?
Any updates?
NetCrashNG
Apr 27, 2022Tutor
- FURRYe38Jun 29, 2022Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
