GD2BKG
May 09, 2022Initiate
RBR750 CONNECTION_REFUSED loading admin interface
I have the same problem.....note the date(s) when all these problem were reported/documented.
May 09, 2022Guru - Experienced User
does it work if loading through the browser and not the app?
We've had a ton of reports over the last week of connections issues.
Some were fixed with a factory reset/reinstall.
Others (ios devices) needed to disable icloud relay and private mac/ip address.
- MB_LoveMay 09, 2022ApprenticeNo it doesn’t work via any method- even wired you can’t connect to router!!
