c345r789t10's avatar
Dec 18, 2022
RBR750 connectivity signal strength
I have ORBI  RB753, router and 2 satellites.  Firmware version v4.6.14.3.
I contacted phone support, and we already factory reset each satellite, and the router and flashed to this most current firmware version.  They suggested I post to this forum.
My issue is two-fold:  1) Devices will not connect to the first satellite.  I can stand right in front of it and my device will not show up in the Orbi app under that satellite.   2)  When I stand next to the second satellite my device does connect, and the dBM while averages very good (~-40), it also bounces around alot (-60 to -20 )while me device is just sitting there.  Notably, the signal strength also fluctuates--80% to 50%, never 100%.  It does this with my device stationary ~2 feet from the satellite.
So, how do I get the 1st satellite to presumably work, and can anyone explain what is going on with the second satellite?
Thanks for the help!
1 Reply
  • FURRYe38's avatar
    Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
    What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR and RBS🛰️ to begin with depending upon building materials when wirelessly connected.
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰
    What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
    Some devices will not auto roam or connect to the nearest RBS. You have to disable the devices wifi radio for 5 seconds then turn it back on.
    Swap RBS locations with each other to see if the problem follows as well.
    Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
    Turn off and unplug modem.
    Turn on computers and rest of network.
