baleitzell
Aug 23, 2020Aspirant
RBR750 Constantly Dropping Connection
First, the model of my Orbi is a RBR750 (as it shows up in the interface). On Netgear's website where I purchased the system, it says RBK752 AX4200. There isn't an option for either of these on the d...
Shango22
Jan 28, 2021Aspirant
I am very unhappy with this product. It's stability sucks. I had a google wifi which was not wifi 6 and it's a much better product. I really can't believe this router had such good reviews. First my guest network would have no internet connection. The wifi would connect and intermittently drop the actual internet connection constantly. Then I finally quit using the guest network which I had hoped to use as a secondary private network with less interference. Now the primary network does the same thing. I don't understand for the life of me why you can't control the radios independently either. I guarantee it's an issue with merging the 2.4 ghz and 5ghz radios. I am so disappointed that I threw the box away and then hesitated to return this piece of garbage. My wife's work laptop cannot see the network at all. No idea why. Seems to be an issue with enterprise windows and this router. My alienware now never connects directly to my network when I turn it on. It sucks and it's absolutely the router.
Jan 29, 2021Guru - Experienced User
Then return the system and find something else.
Good Luck.
