baleitzell
Aug 23, 2020Aspirant
RBR750 Constantly Dropping Connection
First, the model of my Orbi is a RBR750 (as it shows up in the interface). On Netgear's website where I purchased the system, it says RBK752 AX4200. There isn't an option for either of these on the d...
Tombyrne
Aug 26, 2021Aspirant
OMG is the purpose of this device to cause pain? As I am writing this from my phone the WiFi from the new RBR750 i just purchased is dropping in and out. My wife who tried to work at home today wants to kill me. Is it to advanced for human kind to pull off? I like the fix suggestions. They gave me a real headache. Are you kidding me? How about I plug the thing in and turn it on, ok? That’s what I need. Something that just works. Wow. What a bummer.
Aug 27, 2021Guru - Experienced User
Try using some of these setting here:
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
Armor, Circle, Set 20/40Mhz Coexistence to 40Mhz only. Set CTS to 2347. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings
