baleitzell
Aug 23, 2020Aspirant
RBR750 Constantly Dropping Connection
First, the model of my Orbi is a RBR750 (as it shows up in the interface). On Netgear's website where I purchased the system, it says RBK752 AX4200. There isn't an option for either of these on the d...
Tombyrne
Aug 26, 2021Aspirant
OMG is the purpose of this device to cause pain? As I am writing this from my phone the WiFi from the new RBR750 i just purchased is dropping in and out. My wife who tried to work at home today wants to kill me. Is it to advanced for human kind to pull off? I like the fix suggestions. They gave me a real headache. Are you kidding me? How about I plug the thing in and turn it on, ok? That’s what I need. Something that just works. Wow. What a bummer.
ak45
Aug 27, 2021Aspirant
Hi everyone, just wanted to update my status. I called my internet company (COX), to send someone to check my incoming connections and they found that they had a really bad splitter that was causing interruptions. They changed the splitter, and I do not have the issue anymore. Somehow this was not an issue withe earlier routers.
- FURRYe38Aug 27, 2021Guru - Experienced User
Glad it was the ISP thing. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy.
