baleitzell
Aug 23, 2020Aspirant
RBR750 Constantly Dropping Connection
First, the model of my Orbi is a RBR750 (as it shows up in the interface). On Netgear's website where I purchased the system, it says RBK752 AX4200. There isn't an option for either of these on the d...
ak45
Aug 27, 2021Aspirant
Hi everyone, just wanted to update my status. I called my internet company (COX), to send someone to check my incoming connections and they found that they had a really bad splitter that was causing interruptions. They changed the splitter, and I do not have the issue anymore. Somehow this was not an issue withe earlier routers.
Aug 27, 2021Guru - Experienced User
Glad it was the ISP thing. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy.
