tickytock
Feb 08, 2021Initiate
RBR750 (Costco set) only get 85-98mbps on 275 mbps Xfinity (Comcast ISP)
Hi, I purchased the Costco RBR750 set and running on Xfinity (Comcast) 275mbps plan but I only get 85-98mbps average in all my wireless devices. Any suggestion? Did I set it up wrong? Pleas...
Feb 08, 2021Guru - Experienced User
What devices are you using to speed test with?
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
Armor, and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).
You can find other speed diagnosis steps in the community faq: https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-t-my/m-p/1982974/highlight/true#M7849
