campolo313's avatar
campolo313
Apprentice
Jul 05, 2022
RBR750: Devices will only connect to Satellite WiFi or Ethernet Ports
None of my devices will connect to the Router's WiFi (both the 2.4 GHz and 5 GHz channels), devices are all connecting to the Satellites, Backhaul is showing as good, and devices that are connected t...
  • campolo313's avatar
    campolo313
    Jul 09, 2022
    Definitely wasn’t a faulty router, I’ve had this RBK753 for two years and the only issue before was the NAT Filter on their firmware at launch.
    Plus the issue with the App showing the router being offline continues with my new RBK853, so there definitely is a bug with the App, but devices still connect without issue, just an issue with appearance.
    So that App issue was just coincidence on timing, but my guess is somehow the front end radios either went out or an update ended up bricking them.
    I’ll be sending in a warranty claim, so I might have other information later.
