costler
Jun 23, 2022Tutor
RBR750 DHCP
I have an Orbi RBR760 connected to my cable modem, also Netgear. My network Gateway / DHCP is 10.0.0.x. Works as advertised, most of the time. However, I noticed a number of connected devices that...
SeaRefractor
Jun 24, 2022Apprentice
I noticed that there had not been a mention of the service you are using to connect to the internet.
There might be a fourth option.
I had double-NAT issues and while I could put the modem/router into bridge mode, I still wasn't pleased with the performance.
I have Fiber to the home (CenturyLink). So I had an Adtran ONT -> Zyxel C3000Z -> Orbit RBR750.
I found out the settings I needed from CenturyLink support (my PPPoE username/password and the VLAN tagging I required) and configured those on my Orbi RBR750 and returned the Zyxel C3000Z to CenturyLink. No need to lease the modem any more.
I don't know if this at all applies to your setup, but I wanted to post that there could be a fourth option (if ethernet handoff is provided from an ONT device that is not the Modem/router) if a similar setup.
Jun 24, 2022Guru - Experienced User
In this case they have a CAX30. Similar to the CAX80 I have. Can run double NAT and should work. However when encountering odd LAN IP addressing problems and such, sometimes it makes things easier to put the CAX to modem only mode and then run the RBR in router mode. KISS. 😘
