palanzana
Feb 26, 2023Aspirant
RBR750 disconnects
i have the same problem...did u resolve it?
Mar 06, 2023Guru - Experienced User
- palanzanaMar 08, 2023Aspirant
hello, I solved..it was an isp problem
- FURRYe38Mar 08, 2023Guru - Experienced User
Glad to hear. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
