JSJ34
Jan 16, 2021Aspirant
RBR750 does not allow my NUVO Music System to access network when plugged into port
Our ORBI RBR 750 works perfectly with all wireless devices including MyQ, ecobee, Ring etc. It also works fine with our Control 4 that is plugged into one of the ethernet ports. The problem is when...
- Jan 18, 2021
Glad you got it working. Mark yoru thread as solved so others will know.
Enjoy. :smileywink:
Jan 16, 2021Guru - Experienced User
Please post about this over in the Orbi AX forum:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Thank you.
- JSJ34Jan 16, 2021Aspirant
Thanks. Followed your advice.
