JSJ34
Jan 16, 2021Aspirant
RBR750 does not allow my NUVO Music System to access network when plugged into port
Our ORBI RBR 750 works perfectly with all wireless devices including MyQ, ecobee, Ring etc. It also works fine with our Control 4 that is plugged into one of the ethernet ports. The problem is when...
- Jan 18, 2021
Glad you got it working. Mark yoru thread as solved so others will know.
Enjoy. :smileywink:
JSJ34
Thanks. Followed your advice.
Jan 16, 2021Guru - Experienced User
:smileywink:
- JSJ34Jan 18, 2021Aspirant
Problem fixed. Was an IP conflict with the AT&T modem as when it was installed the tech was supposed to turn off the router and did not.
Appreciate the help FURRYe38!!!!!
- FURRYe38Jan 18, 2021Guru - Experienced User
Enjoy. :smileywink:
