Hsri07
Aug 22, 2020Tutor
RBR750 download speed drops a lot and below upload speed some of the time
I installed the AX 4200 RBR750 router + 1 satellite a couple of months ago and it worked well - consistently 200Mbps+ download, 32Mbps+ upload everytime I checked (at different times of the day or at...
- Aug 30, 2020
It was Optimum cable that had the problem. The technician came, fixed something in the cable box on the street and it is fine so far! Thanks for the responses and apologies for the time.
Hsri07
Aug 22, 2020Tutor
Cable Modem is Arris TM1602 - swapped in a new one 2 days ago (yes, I can get a new cable modem myself and use it but would like to resolve this issue first and then consider getting my own modem).
Re: other questions - two things to note - first, it worked perfectly fine in the same home, same place where the router & satellite were setup earlier, nothing has changed. We have no wifi interference and no additional electronic devices in the past few months. Secondly, it worked perfectly at 12pm EST but is dropping speed at 4:30p EST same day.
No Armor. I will try the other changes you suggest below but I am still confused as to what can cause something to change between noon and 4:30pm same day after I have done a factory reset, hard booted everything and it all seemed to work fine? Does the fact that it remains
"On" for a few hours cause a decay in performance? And it all worked well for 2 months, has this firmware update caused problems? Or the storm has cuased problems with the cable modem and cable internet?
Going to hardwire ethernet to my laptop to the cable modem to test that and also hardwire ethernet to the RBR750 to test that too.....
Aug 22, 2020Guru - Experienced User
You might revert back FW versions. Something maybe different on the 7 series vs 8 series Orbi.
I would make contact with NG support about this as well.
- Hsri07Aug 23, 2020Tutor
More weird results, after download speed plunged at 4:30pm EST, we stepped out and when we returned home around 8pm, speed was back up to 198Mbps download!! Upload stays good all the time, it is always the download speed that plunges.
And today morning (8/23), speed has plunged back down to 4Mbps!
All this time since 12pm yesterday 8/22, absolutely nothing has changed and I have tested on 4 devices, so it is not a device problem.
To repeat:
- RBR750 with 1 router and 1 satellite working fine for approx 2 months. Firmware was updated 4 days ago. I am noticing very erratic performance in download speeds only, upload is always fine. have hard booted cable modem and router/satellite multiple times. 8/22 morning, factory reset router & satellite and it seemed that it was working properly (download speed 200Mbps), 4:30pm speed dropped to around 10Mbps, 8pm back to 198Mbps, 8/23 morning back down to 4Mbps. No changes anywhere during all this time!
Going to test laptop with ethernet to cable modem and then to router to see if I can isolate the problem.
- FURRYe38Aug 23, 2020Guru - Experienced User
And a factory reset and setup from scratch was performed on the RBR after the update?
Was your system updated automatically, via orbi app or did you manually apply the FW update files yourself?
I did a factory reset (atomatic update from orbilogin.com) after the firmware update. Once the factory reset was completed, I did a firmware update availab;e check and it said no new firmware update i.e. the last update remained after the factory reset. Going to check internet via ethernet cable and laptop shortly.
