jovialone
Jul 21, 2023Aspirant
RBR750 Download speeds faster than 10MB/s cause Purple light
I have an RBR750 and two RBS750. Has anyone run into download speeds over 10MB/s causing the internet connection to die and the router throwing the purple light? This used to happen to me with Adobe...
Jul 21, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What is the brand and model of the switch?
Armor, Smart Parental Controls or Circle, Traffic Meter.
- jovialoneJul 21, 2023Aspirant
Current version of firmware is 4.6.911_2.3.5 and I am currently upgrading to 4.6.14.3
The switch is the GS105 (https://www.netgear.com/business/wired/switches/unmanaged/gs105/)
I purchased my modem seperately from the ISP and it is a Netgear CM1000.
I never had and verified that the listed features are not enabled.
The cable is one I assembled myself from a bulk spool and will pickup some Cat6 next time I go out.
- FURRYe38Jul 24, 2023Guru - Experienced User
Please post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router- jovialoneJul 24, 2023Aspirant
Ok. My replies have disappeared four times now. I give up. The log has no entries on the day the orbi went down. In either direction +-2 it just shows a CM-Status message sent and a DHCP renew warning from 6/28/23.
The cable connection shows good. I can try to screenshot that page if it would help.
