mattg1960
May 13, 2022Star
RBR750 Drop Wifi for 3-4 Minutes Multiple Times a Day...
Yes, I am having the same issue as everyone else; I can't access the router via a browser or the app. But, like many, I also have Wifi (sort of). I could live temporarily with not accessing t...
May 13, 2022Guru - Experienced User
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
d Set 20/40Mhz Coexistence to 40Mhz only. Set CTS to 2347. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Setting
mattg1960
May 13, 2022Star
V4.6.5.14
It is Netgear CM600
4,000, 2-story. Modem and router upstairs, 1 satellite in living room and 1 in the kitchen (both downstairs).
About 30 feet between the two satellites. More than that from the router to either satellite.
The main (family) network is 5GHz. The guest network is 2.4GHz, both password-protected with different passwords. I cannot change settings as I don't have access to the router.
There are 6 or 7 Wifi networks that show up on my MacBook Pro. All of them are password-protected.
I can't do any of this as I don't have access to the router.
I appreciate your help, and I see that you are a major contributor here and obviously very techincally-minded. But this goes to my main issue; this is a consumer product and Wifi technology is more than 2 decades old. If I wanted to be a network administrator I would have bought a commercial-level product like Ubiquiti. I don't and I didn't.
If I ever get router access back I will try your suggestions. I am giving NG until next week and if I can't get access and can't stop dropouts I will be returning it to Costco if I can.
I just want something that can cover my house, provide 200Mbs download speed, and can stay up and running without a babysitter. I don't think I'm asking for a lot, especially considering the price of these units.
Thanks again...
- mattg1960May 13, 2022Star
Btw, I highlighted your questions in red, but when I posted it turned all the type to black, making it harder to read, so my apologies.
Even this forum doesn't seem to work : )
- FURRYe38May 14, 2022Guru - Experienced User
You'll need to factory reset the RBR and setup from scratch using a wired PC and Web Browser at HTTP and 192.168.1.1
- mattg1960May 14, 2022Star
Kind of pointless if a consumer product is this user-unfriendly. Like I said, I'm not an IT tech and my Mac does not have the right connection for the cable, so now I have to go out and buy some sort of converter.
How about 1: NG fixes the dropout issue and 2: NG updates the firmware to allow me (and seemingly thousands of others) to access our routers either via the app or a browser?
This should not be difficult for a half-billion dollar company...
Sorry for the frustration, but all of the 'just do a factory reset' answers are sub-optimal for many.
Understand the frustrations. Along with everyone elses and mine as well.
So NG is aware of the issues. Please review the top status for that information.
The only way to regain access to the RBR is a reset thru a wired PC connection and web browser.
USB to ethernet adapters are fairly cheap and easy to use. I have a few on hand.
