BigStyz
Feb 24, 2025Aspirant
RBR750 dropping connection and poor network quality
I began experiencing network issues 2 weeks ago. Day 1 and Day 2, no internet for 15-30 minute segments over the course of 4 hours each day. On each of the subsequent days, the internet has staye...
- Mar 09, 2025
Problem solved. Thanks for the insight. The ISP made 3 trips to the house, and each tech "found" something new and wrong on their end. After tech #3, the errors went away and speeds are back up. It was not a hardware issue, but it took a lot to get to that answer.
BigStyz
Mar 09, 2025Aspirant
Mar 10, 2025Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
