lipstick
Feb 01, 2023Guide
RBR750 dropping internet after 10 mins of every reboot
I am forced to use Comcast Xfi Modem to avoid paying extra for unlimited data. But I have Wifi turned off on the comcast modem and instead I am using 3 Orbi's in AP mode. The setup has been work...
Feb 01, 2023Guru - Experienced User
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Check the ISP modem if the RBR is turning PINK while in AP mode:
https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-mean
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
- lipstickFeb 01, 2023Guide
thank you for your reply.
yes, i did restart my xfinity gateway modem and made sure it's working before connecting my orbi router.
my ISP modem's internet connection is stable while RBR750 is purple. so the issue is definitely with my Orbi.
i do have CAT 6 connected between modem and orbi.
this is the modem: XFI ADVANCED GATEWAY (XB7)
- FURRYe38Feb 01, 2023Guru - Experienced User
Be sure the ISP Modem is giving the RBR services and a IP address. One reason for the PINK led is that the RBR isn't getting anything from the ISP Modem. Setup a IP address reservation for the RBR in AP mode.
Are you using Dynamic or Static IP address configuration for the RBR in AP mode?
Might try the RBR in router mode and use the modems DMZ for the RBR.
Try a factory reset and setup from scratch.
Orbi still works for like 10 mins so it is getting the right IP address.
- KevinLiTFeb 01, 2023NETGEAR Moderator
Hello lipstick,
Welcome to the NETGEAR Community!
I understand that you are having interim disconnects with your RBR750. Please try changing your Comcast Xfi modem to bridge mode then change your RBR750 to router mode.
Please keep us informed of the progress of this issue!!
Best,
Kevin
Community Team
but Orbi should still work in AP mode right? why is it needed for me to use my xfinity gateway in bridge mode? i want my continue to use my xfinity gateway as a router.
